Porter Cable 690: a question http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=11168 |
Author: | Mattia Valente [ Sun Mar 04, 2007 5:45 am ] |
Post subject: | |
...on an additional note, I was planning on mounting my 690 upside-down, in a home-made table setup, and I ran into a little problem: how to mount the darn thing. I was thinking of 'simply' mounting it using the three tapped holes in the base, but then realized I can't actually go down to the local shop and get any US-standard bolts. So, could any of you guys with 690's tell me what thread/size screws I need to order (wanted to get some stuff from McFeely's anyway) to fit the 690's thread? Thanks in advance. |
Author: | JJ Donohue [ Sun Mar 04, 2007 6:39 am ] |
Post subject: | |
Mattia...why can't you just remove the screws from the router plate and use the same ones to mount the router to your table plate? Anyway...they're 24TPI and 3/16". You may need a few different lengths. I'd suggest 1/2" and 3/4" for starters. |
Author: | Mattia Valente [ Sun Mar 04, 2007 8:23 am ] |
Post subject: | |
Thanks for the info,. It's the length issue; I haven't settled on the material for the table plate yet, but I'd like to go a little thicker than the router's own baseplate. |
Author: | crazymanmichael [ Sun Mar 04, 2007 10:18 am ] |
Post subject: | |
mattia, pm me with your address if you need some sent over... |
Author: | Dave Anderson [ Sun Mar 04, 2007 10:51 am ] |
Post subject: | |
Mattia, The ones I used in mine are the same as JJ's but 1" long. |
Author: | Jim Kirby [ Sun Mar 04, 2007 12:56 pm ] |
Post subject: | |
[QUOTE=JJ Donohue] Mattia...why can't you just remove the screws from the router plate and use the same ones to mount the router to your table plate? [/QUOTE] That's what I did. Got a Rousseau plate and built a table top for it, and just reused the original screws. Jim |
Author: | Steve Saville [ Mon Mar 05, 2007 2:46 am ] |
Post subject: | |
[QUOTE=JJ Donohue] ...they're 24TPI and 3/16"......[/QUOTE] JJ, Could it be a #10-24? 3/16" = .1875" #10-24 is .190". |
